my roper stopped working when it came to the spin cycle…started smelling like an electrical problem. Will not empty, cannot drain, and it is making a ticking noise along with a sound that sounds like it is winding down…please give me any advice you can on how to repair. We think it may be a water pump. thanks
If it’s less than a year old as stated above call a Whirlppol technician for service. If not here’s a breakdown of your machine. Replacement parts for WHIRLPOOL RTW4340SQ0 | AppliancePartsPros.com
Most likely the coupler, located between the pump and motor wore out. you can raise the top and remove the front panel to access the interior of the machine.
Nat
