Will Not Turn On. I Replaced The Lid Switch.
Will it fill with water? If so, check for loose screws on the left side lid hinge. This can prevent the hidden lid switch from operating.
Eric
it does not come on at all. I checked the outlet and it is good. replaced the
lid switch. nothing seems to work. think maybe its the timer?
It could be the timer. Timer can be returned if it doesn’t fix the problem.
Whirlpool W10199989 Timer - AppliancePartsPros.com
Eric
