My washer gets to the final rinse and just continues to add water slowly. Will only move on to spin when I turn the dial.
Not clear on your symptoms. In rinse cycle, the washer should fill, agitate, drain and spin. At which point is the problem occurring?
Eric
[quote=fairbank56;812129]Not clear on your symptoms. In rinse cycle, the washer should fill, agitate, drain and spin. At which point is the problem occurring?
Eric[/quote]
Hi Eric,
When it gets to the last rinse cycle the water just trickles in. The first time I noticed it, it had been running for probably an hour and a half!!! I advanced the dial forward a little and it went into the spin cycle. Now that I know it’s getting stuck in that spot I watch it and just advance it at the point. Someone said maybe the water pump but I was thinkin in might be the timer going bad. Just want to make sure before I spend the $100 for a new timer. I do have to say that I LOVE my Roper!!! No fancy machine for me
Thanks for any help. Jeanne
So, it’s going into the final spin/spray but only doing the spray? Sounds like a faulty timer to me. If you buy it from APP, you can return it if it doesn’t fix the problem.
Eric
[quote=fairbank56;812135]So, it’s going into the final spin/spray but only doing the spray? Sounds like a faulty timer to me. If you buy it from APP, you can return it if it doesn’t fix the problem.
Eric[/quote]
Thanks, that was what I was thinking might be wrong. I didn’t know that they would take it back. Good to know! Now off to fix my washer ![]()
