Was using my washer this am and did a few loads. on the last spin cycle of the last load most of the water drained into my laundy tub, but it has stopped draining and ther is a different sound to the unit not overly load just a different sound, Any info help greatly appreciated.
its kind of a louder hum, it agitates and spins. With the diagrams from the other post you sent, I am going to haul the box off and check the pump and the in/out lines for foreign material.
Thanks for the info Gene. I hauled the housing off and checked the incoming and out going lines from the pump , and sure enough there was a toddlers blue Old Navy sock stuck there. Checked a couple cycles and seems to be draining fine. We will put her to the test shortly.
Thank you ,
Maximum Destruction ( my little boy came up with this name)
