Roper washer vibrates bad
My Roper washer vibrates bad when loaded. Any ideas what could be wrong, I haven’t replaced any parts yet.
You need to take off the cabinet and by pass the lid switch and then operate it with the cabinet off to see if you can determine the problem.
Before you start it though, mannually inspect the support frame for a crack, and theck the springs to see if one is broken or has fallen off.
