The washer will fill but thats it. Motor, agitator and drum will spin by hand only. There’s no hum except when trying to fill. Seems like motor is not getting any power at all.
Most likely the problem is a bad lid switch (#11 on the diagram)
- The part number for the lid switch is AP3100003
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RAS8244KQ0 | AppliancePartsPros.com
Thanks Gene, you were exactly right. I took the switch off and the clamps holding it together had come apart. Thanks so much!! I don’t need to order a part but I will keep you guys in my favorites and will order from [COLOR=red]you:) [/COLOR] whenever needed.
[quote=Gene;84802]Most likely the problem is a bad lid switch (#11 on the diagram)
Gene.[/quote]
You are welcome. I’m glad it was that simple.
