I have a Roper Top Load Washer Model # RAX4233PQO, It filled up with water and then stopped working. It acts like it is getting no power. The outlet that it is plugged into is fine. I have moved the knob to different cycles, but it will do nothing. Thanks
First place to check is the lid switch. If that is not the problem, tell us what you found out, and if the machine will drain if you move the timer to the end of the wash or rinse cycle.
