Roper electric built-in oven
when oven was turned on and temperature set. f4 code came up and beeped. i turned off power and turned back on to stop beeping. where can i get the codes for roper oven? (i am an electrician)
[quote=davidosmith@bellsouth.net;58921]when oven was turned on and temperature set. f4 code came up and beeped. i turned off power and turned back on to stop beeping. where can i get the codes for roper oven? (i am an electrician) please inform me what f4 code is if i can not receive all codes on this model.
