Roper elec dryer wont start
This dryer is 1.5 yrs old. it will not start. I checked and I have 240 at wall and at cord terminal. I have continuity on thermal fuse also i tried bypassing the door switch…any ideas? Thank you in advance
Check the push-to-start switch for continuity. It should read close to 0 Ohms while it’s depressed. If the reading is incorrect, replace the switch.
Here are the breakdown diagrams and Replacement parts for Roper RED4440VQ1 29"ELECTRIC DRYER | AppliancePartsPros.com
[quote=Gene;700156]Check the push-to-start switch for continuity. It should read close to 0 Ohms while it’s depressed. If the reading is incorrect, replace the switch.
Gene.[/quote]
I just tried that still no start
How did you do it?
How did you bypass the door switch?
Does the dryer make any noises when you tried to start it?
[quote=Gene;700859]How did you do it?
no noise…I unpluged the door switch and took a small wire and made a closed circuit on the connector from the dryer.
Gene.[/quote]
Check for 120 VAC between any of the thermal fuse terminals and the ground while the timer is On and the door is closed.
Post the results.
