Roper dyer just stopped. Checked main fuse panel it didn’t trip. checked thermal fuse on blower housing it was good. Is there another fuse somewhere else i can check or what might be the problem. Dryer is only a year and half old. MODEL# RED444OVQ1
Replacement parts for WHIRLPOOL RED4440VQ1 29``ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
You could check the unit by unplugging it and setting the timer to mid-cycle timed dry with the door closed. Set your scale meter to about 200 ohms.
Now measure between Neutral and L1 at the power cord end.
It should be infinite ohms.
Push the start button and the resistance should drop to pretty well zero re: you should see the motor coil resistance about 2 ohms.
If it does then I would check the power.
An alternate method is to check the power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is OK then check the door switch and the push to start switch to see if they are closing.
EED4300.pdf (548.9 KB)
