Roper Dryer won't start
My Roper Dryer just stopped working, will not start at all. Any suggestions where to start troubleshooting?
Hi.
First check if there 240VAC at the wall outlet.
If yes, then unplug the dryer, remove the back panel and check if the thermal fuse on the blower housing is open.
Replace if needed and clean all air vents, including the chute.
The fuse AP6008325
Here are the breakdown diagrams and Replacement parts for Roper RED4440VQ1 29"ELECTRIC DRYER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
