Roper Dryer will not start
My Roper Dryer will not start, no tumble and no heat. I checked the fuse, and door switch. I checked the start switch and made sure it opened and closed on the blue wires. The continuity looks good. Is there a common problem on this dryer?
In addition to my first post, I tested the motor with 115vdc and it tested ok. I rotated the Timer manually to see if the buzzer would go off and it did not. So if does that mean the Timer may be bad? Is ther any other way to knowif the Timer is bad?
Jump out the thermal fuse, and then plug the unit in and see if it works. Tom ApplianceEducator.com
