Our Roper model RED 4440 SQ 0 dryer tumbles the clothes but it is not heating up.It is on the setting for heated dry.What might cause this ?
Replacement parts for Roper RED4440SQ0 29"ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
No heat can be a bunch of things.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
Looking at the wiring diagram, the timer runs off of 240 volts when in timed dry. Put the unit to mid cycle timed dry. If the timer advances then you have 240 volts. Doing it this waay is safer than poking around 240 volts with a meter.
If OK
Next I would check the heating coil. They are usually 8 to 12 ohms.
If OK.
Check the thermal cut-off (Item 9 in Section 1). It should be 0 ohms.
If it is blown get post a reply as you have to find out why it blew.
If OK
Check the other thermostats. Both should be 0 ohms.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
RED4440.pdf (190.2 KB)
