I recently moved into a house where the dryer worked for a couple of loads and then simply would not turn on when a new load was placed inside. I do not know if the problem is in the switch or the moter. Everytime I press the switch nothing happens.
I have a roper dryer and recently just stop heating.Would somebody help me
and tell me whats wrong with it?![]()
In order to provide the most accurate advise I need the complete model number of your dryer. You can find it on the door frame.
Please, post it as a new thread.
I have a roper dryer electric that I turned on when I went to work last night it dryed everything, My wife got up at 3 am and the dryer was still running but with no heat. I have it running now no heat.
Mod #MR5044615
I will be going to work in a little while, if you wouldn’t mind sending help to my e mail, if not that is ok
den44@juno.com
Hi Dennis,
What cycle did you use when it was running nonstop?
Looks like instead of the model number you posted the serial number.
Verify and repost it, please.
Roper dryer is Ser#REX3514PQ0
TYPE D433-ELE 2406028-FM54
It says the auto sense dry side of the dial, which is on the left side.
Dennis Langer
den44@juno.com
Hi Dennis,
On the same name plate where you found the serial number suppose to be the model number.
Mod #MR5044615 I believe this is the Mod #
