Hello,
I have a Roper Dryer.
It runs fine, but with no heat.
I removed the back and checked all the sensors and fuse inside, and had continuity on all.
Can I have continuity and it still be broke, or is it something else, maybe the timer?
The first thing to check when you have no heat is the power.
The motor runs on half the line (120 volts) but the heater requires the full 240.
On this unit the timer also uses 240.
Place the unit in timed dry and start it.
Does the timer advance?
If not it is probably a power problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR] RED4440V.pdf (138.3 KB)
