I have a Roper dishwasher 2 years old that won’t drain. Is it possible to buy the pump without the motor or just order all the parts seperatly and rebuild it.
Hi kennyl
Why do you think the problem is a bad pump?
Did you check the drain hose and the air gap on top of the sink?
If the pump got stuck but the motor is still good and the pump is not leaking you do not have to buy the whole assembly. It is possible to rebuild it. Here are the parts you have to buy:
The impeller kit, part number AP3108052
The disk-mount, part number AP2909490
Here are the break down diagrams for the Roper dishwasher Model RUD3000KQ1
Good luck.
