How do I repair hood switch on my kenmore washer
how do I replace hood switch on my kenmore washer
I’m assuming the part you called “hood switch” is the lid switch (#11 on the diagram)? This part is not repairable and you have to replace it. In order to access the part you have to open the console and remove the washer cabinet. The instructions are attached to the reply.
- The part number for the lid switch is AP3100001
How to remove the washer cabinet.pdf (43.5 KB)
