Door strike is broken and broken part is in door do we need to remove broken piece before replacing the strike
Simon,
Broken part is in the door latch (upper hole)
Simon,
Hi.
Sorry. Do you mean the broken off piece is inside the door latch not inside the door?
Simon.
[quote=DALRO;730317]Door strike is broken and broken part is in door do we need to remove broken piece before replacing the strike
Simon,
Broken part is in the door latch (upper hole) I can see the broken part but it is hard to remove do you have a suggestion
Hi.
In your case I recommend to replace the door latch also.I know it’s much more $ but the chance that you will damage it trying to remove the broken piece is very grate.
The door latch [PART]131763202[/PART]
The strike [PART]134456600 [/PART]
Here are the breakdown diagrams and Replacement parts for Frigidaire ATF6000FS1 WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
