Washer will wash but will not spin water out. It drains but doesnt spin. Sometimes it spins, but not lately
This is a direct drive Whirlpool model, so if the drain action does not stop check out the clutch and try replacing the clutch lining. While you are in there check the brakes to make sure they are releasing as they should.
