Rinse dispenser not releasing rinse aid
I have noticed that my rinse aid is not discharge from the rinse dispenser.
I run it every other day but not have refilled the liquid in the last two months.
Do I need to replace the rinse aid dispenser.
Parts for Whirlpool WDT790SAYM1 / Dishwasher - AppliancePartsPros.com
I am assuming that the rinse aid used to work OK.
If yes then it needs replacing.
If no then check the setting in the following manual (page 7).
You may want to try a higher setting even if it used to work OK.
http://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10596244.pdf
WDT790.pdf (931.6 KB)
Thanks Denman.
Is there a guide to replacing the rinse dispenser for this dishwasher.
