Rinse cycle will start filling and stop with little water
In any Mode, It will run perfectly until RINSE, when it starts filling and suddenly stops with very little water, the Cycle will continue, so you need to add water manually. Tried changing the valve, but did not work, the repair man says that we could try changing the Control Panel and Timer, think this is just a try/fail solution and very expensive.
ANy suggestions ? could it be the Rinse fill switch?
Tks for yr help
You are right, the tech is doing a “try and see if this works” approach, but that is what you do with this model.
If you buy the parts from this site and they do not fix the problem you can return them, see the returns policy for details and instructions.
Also, visually check the board for any burned resistors and if you have not changed out the wax motors, you need to do so.
Thanks for the reply but I^m in ARgentina and to buy the parts and then return them is a big problem, so I have to be more accuate, can you help me give me some suggestion to try first ?? tks for yr help
Yeah, sorry the try the parts approach does not work for Argentina.
Your model is one of the most troubled machines ever made, and about the only thing I can do is link you to a service manual for the model.
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B5If-wTgYWH5YWI2NjQyZjItMjlhMy00MjM2LWJmYjgtYmY3YjRkZTQ1OWNm&hl=en_US
There is just no way we can give you a definitive analysis for your problems with your machine, and if a new washer is an option I would strongly urge you to consider that.
Good luck, sorry not to be of more help.
