rinse agent dispenser is not working. any suggestions?
Your model number seems to be missing the first 3 digits.
This tells us who actually made the unit, see the following.
http://www.appliance411.com/purchase/sears.shtml
Many units use a dispenser with a wax motor, it is fairly common for these to burn out.
Here is a good site with basic dishwasher repair info.
http://www.applianceaid.com/dishwash.html
mfg 665, Whirlpool. Remove door cover from inside and replace the wax motor? nothing to clean or unclog?
I would check the unit for a mechanical fault also could check the wax motors for resistance. Most of them are around 2,000 ohms.
Probably not but worth taking a look.
