Reversing door hinges
Is there any instruction available for reversing the door hinges on a GE model TBX25RKBR refrigerator freezer? We need to have the doors open on the right side instead of the current left side. Are any different or new parts needed to make this conversion?
Your model number seems to be short a couple digits.
Go to the GE Appliances website and under “Service & Support” doownload the Owner’s Manual, it should be in there.
I went to the GE website and downloaded the owner’s manual. It does not contain any information about reversing the doors. The full model number from the back of the unit is TBX25RKBRWH and that is what I used on the GE website to locate the manual.
Any other help or ideas are appreciated.
I tried using the full model number and the manual is sort of useless.
Try using TBX25RKBR on the GE site. I then get a totally different set on manuals.
I have no idea why this is.
But if you look at the TBX25PBRWW manual it does have door reversing in fo.
Note that if your unit has an ice/water dispenser in the door it is not reversible.
Thanks for the help. I found the manual and will try to reverse the door this weekend. Then I can see about the freezer defrost problem.
Eric Berg
