I have a problem with my Quiet Partner 3 from Whirlpool.
I’m not completely clueless to repairing things around the house (the lawn mower, the kitchen sink, the toliet)… but I’ve never really dealt with large appliances so if you can help me, I need detailed help. ![]()
We’ve had our dishwasher for about 2 years. This summer, my normal light started blinking. I hadn’t been using the dry function, instead I was cracking the door and letting it air dry. I searched and searched and finally discovered how to reset the unit. It still blinked occasionally, but I could usually get it to stop by just pressing the blinking light, cancel and start all at the same time. I started using the dry cycle again and it stopped. I figured moisture had gotten into the panel and finally dried up once I started using dry again.
Skip forward 5 months. I believe we had a power outage 2-3 weeks ago because my mircowave (also on same breaker switch as dishwasher), was at all 0’s. Since then, my normal light has been blinking, or I will come home after running a cycle and normal and the light to the left (I believe it is pots and pans) are blinking back and forth.
Today I loaded it, and went to start it, but the normal button was blinking. I pressed normal, start, drain as usual to get it off, but it didn’t work. Instead, now I’ve got cancel, normal and pots and pans blinking.
I turned the breaker off 15 minutes. Turned it on, and tried to reset it with the reset code sani rinse-dry sani rinse-dry. It’s suppose to light all lights and then reset, but it doesn’t do anything. I reset the breaker again and tried it with the door open, pressing buttons and then shutting the door. No such luck.
I hate to call a repair person, money is tight at christmas.
My water heater is working fine, and my dish washer has power since the lights are blinking.
I have no idea where to even begin or go from here. help?
