Reset Sequence for Kitchenaid DW
I had some blinking lights on my KitchenAid DW so I turned off the breaker for a few minutes. Well, that cured the multiple blinking lights, but now the 4 hour delay button blinks on and off slowly. I know there is a reset sequence for DW’s, but I can’t seem to find the one for this model (KUDS30IVSS3) anywhere. Can anyone assist me with that sequence please?
Thank you!
To invoke the Diagnostics Cycle, perform
the following key presses or actions in less than 6 sec
while in standby:
Heated Dry ➙ Normal ➙ Heated Dry ➙ Normal.
The unit should start and run and reset the board.
