Just replaced a main board on a GE washer and was wondering if there was a reset button or anything like that to reset.
Here are instructions for the control board on a model similar to yours. Since GE does not make it tech info available, we cannot say for certain that this will work on your model but it should.
[FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]Note:[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]The replacement control board will always enter
into test mode t01 on initial power-up.
If replacing the control board, the washer will
not function until the replacement control board
has been programmed.
[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][COLOR=#231f20][FONT=GEInspira-Bold][COLOR=#231f20][LEFT]Programming the Control Board[/LEFT]
[/COLOR][/FONT][/COLOR][/FONT][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]1. To program the replacement control board:[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]Reconnect power to the washer. (The display
will now show “—”, which means no model has
been selected.)
- Rotate the cycle knob until the correct model
number is displayed:
Select 1 for model WHDVH626F
Select 2 for model WCVH6260F
Select 3 for model WBVH6240F
Press and hold the Start key for 3 seconds (or
until a second beep is sounded). -
Press the Power key to reset the control.
[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]Note: [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]If an error is made in programming the
control, enter test mode and select t01. Then repeat[/LEFT]
steps 2 thru 4.
