Follow-up question; where or what are the instructions for programming the control board with the personality code (model #) as it appears on the display panel?
I thought it would have been in the mini manual, but I do not see it there.
Did you install a new board?If so what is the parts number? The 29-6242 GE Mini Manual is for your Canadian model.This part of the mini manual is not in the USA one.Try That service mode and see if it helps!
All those parts numbers being up no personality code on GE Parts Site that you can send them a text for part number and they will say if there is any code to program.Have you gone into the service mode on the mini manual and followed every step.There seems to be no code to sent on this.The 29-6242 GE Mini Manual is for your Exact Canadian model.This part of the mini manual is not in the USA one.Try That service mode and see if it helps!
I did some additional seaching on my end and I think the personality programming instructions if any, are provided with a new UI board. In that case, I am not concerned.
What you have provided will suffice for now.
BigBuck1, I greatly appreciate you taking the time to respond to my questions and providing me with this material.
