Replacing washer water pump
To whom it may conern:
I need to replace the water pump in my top load maytag washer model no. mav7757aww. I have found the parts on your website but my question is do I need to purchase both the pump assembly part number AP4372886 and the water pump part number Ap4373022? Please let me know and thank you in advance for your help.
Martin
Hi Martin
Here is a Maytag service bulletin which seems to say that the pump assembly will be all that you need to make the replacement on your model. It looks like Maytag changed the pump and pump assembly on yout model of Atlantis
http://www.servicematters.com/maytag_library/docs/16009485-03.pdf
I would call in the order to APP and have them ascertain that it is that the pump assembly is what you need.
Good luck, let us know how the repair turns out.
