Replacing starter relay on fridge
My refridgerator stopped cooling and was making clicking noises so after pulling the starter relay near the condenser, I saw that it was burned, cinged at the base near the wire. I ordered the correct part Electrolux 5303007171 which is a replacement part since the original part G182225-11 was discontinued. The problem is the replacement part is larger than the original part which makes it impossible to reinstall the box cover
You are missing the spring wire that holds the start device in place. For normal operation, you can run it without the wire.
