Replacing Soap Dispenser
I am tryting to replace the Soap and Rinse Aid Dispenser on my Kitchen Aid Diswasher.. I am having trouble getting the Front Door Panel off to get to the dispenser. I have removed all visible screws from arround the door including the door hionge screws. The top - Control Panel is loose, however there seems to be something near the center of the lower front panel keeping it from comimg loose. :confused:
Air 1,
Here are the basic instructions for removing and accessing the door components,
This ought to get you through the repair.
[FONT=Arial][SIZE=5][FONT=Arial][SIZE=5][LEFT]ACCESSING COMPONENTS IN THE DOOR[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=4][FONT=Arial][SIZE=4][LEFT]Removing the Console Panel[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]The control panel on the KitchenAid KUD01 Dishwasher comes in two versions: a) Split Controls: Top and Front Display and b) Front Display. Both control panels are removed in the same manner.
  1. Remove the six (6) screws securing the control panel to the door .
    2 .The control panel will now drop down and be free of the door assembly. The wiring harness will remain connected to the console components.[/SIZE][/FONT][/SIZE][/FONT][/LEFT]
[FONT=Arial][SIZE=4][FONT=Arial][SIZE=4][LEFT]Removing the Dispenser Assembly[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]The Dispenser Assembly is located in the lower portion of the dishwasher door below the console area.
  1. Remove the eight (8) screws securing the outer door panel to the dishwasher door frame. Remove the outer door panel from the door frame.
  2. Remove the center top hex head screw and remove the dispenser shield and disconnect the wiring harness connectors from the detergent dispenser solenoid and rinse aid sensor.
  3. Remove the remaining five (5) screws securing the dispenser assembly to the inner door liner.
  4. Bend the two locking tabs at the top and bottom of the dispenser assembly up away from the dispenser body.[/LEFT]
  5. The dispenser assembly can now be lifted from the inner door liner.
Good Luck,
[quote=Joe / APP Team;453921]Air 1,
[LEFT][FONT=Arial][SIZE=5][FONT=Arial][SIZE=5]ACCESSING COMPONENTS IN THE DOOR[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=5]
[/SIZE][/FONT][FONT=Arial][SIZE=4][FONT=Arial][SIZE=4]Removing the Console Panel[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=4]
[/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]The control panel on the KitchenAid KUD01 Dishwasher comes in two versions: a) Split Controls: Top and Front Display and b) Front Display. Both control panels are removed in the same manner.[/SIZE][/FONT]
[SIZE=3][FONT=Arial]1. Remove the six (6) screws securing the control panel to the door . [/FONT][/SIZE]
[SIZE=3][FONT=Arial]2 .The control panel will now drop down and be free of the door assembly. The wiring harness will remain connected to the console components.[/FONT][/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][FONT=Arial][SIZE=4][FONT=Arial][SIZE=4]Removing the Dispenser Assembly[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=4]
[/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]The Dispenser Assembly is located in the lower portion of the dishwasher door below the console area.[/SIZE][/FONT]
[SIZE=3][FONT=Arial]1. Remove the eight (8) screws securing the outer door panel to the dishwasher door frame. Remove the outer door panel from the door frame.[/FONT][/SIZE]
[SIZE=3][FONT=Arial]2. Remove the center top hex head screw and remove the dispenser shield and disconnect the wiring harness connectors from the detergent dispenser solenoid and rinse aid sensor. [/FONT][/SIZE]
[SIZE=3][FONT=Arial]3. Remove the remaining five (5) screws securing the dispenser assembly to the inner door liner. [/FONT][/SIZE]
[SIZE=3][FONT=Arial]4. Bend the two locking tabs at the top and bottom of the dispenser assembly up away from the dispenser body.[/FONT][/SIZE][/LEFT]
[SIZE=3][FONT=Arial]5. The dispenser assembly can now be lifted from the inner door liner.[/FONT][/SIZE]
[SIZE=3][FONT=Arial]Good Luck,[/FONT][/SIZE]
[SIZE=3][FONT=Arial]:slight_smile: :slight_smile: :slight_smile: [/FONT][/SIZE]
[/SIZE][/FONT][/quote]
I have removed the 6 screws from the top front panel with the controls on it and that panel comes loose with the wiring harness still attached… I have also removed the 6 screws from the larger door panel and it will not come off to alllow access to the dispenser assembly. Any other thoughts… It appear that the panel is secured about center of the door 4 or 5 inches down from the top of the panel.
Air 1,
The instructions are for your dishwasher, and I don’t recall any hidden tabs or catches holding the panel on the hinge / frame assembly.
You may want to try pushing down on the outer door panel, just in case, but otherwise, I’m at a loss.
:confused: :confused: :confused:
