I am almost done replacing the soap dispenser on my Kenmore Elite with replacement part 8558128, which is a Whirlpool dispenser (recommended replacement part for my model) Everything is going in perfectly, except I don’t see how or where to plug in the little tiny wire/clip part (rinse aid sensor?)on that came off the right hand side of the old one. I plugged the larger wire/clip thing into the left side (electrical source?), no problem. I’m just left with this last little part to complete the job. Can you explain? And is there a SIM card type thing that needs to be moved over (I see something in there and I’m wondering if it needs to be taken out and moved to the new one). I may sound like “a girl”, but I’m really very good at this type of thing, so don’t worry. Thanks.
This new dispenser does not need to be connected to old sensor -it is built in.
