Replacing Pump
Is there an easy way to attach the pump to the motor shaft? I cracked the new pump trying to get it on the motor shaft.
[QUOTE=pdiddy;165]Is there an easy way to attach the pump to the motor shaft? I cracked the new pump trying to get it on the motor shaft.[/QUOTE]
The pump should slide on easily, if it requires force then the motor shaft has rust buildup and will need to be cleaned with a small file and sand paper. Be careful not to remove to much as the two pieced are fitted to prevent slippage and premature pump failure. Once cleaned, apply a very thin coat of grease to the motor shaft to prevent rust and to help with installation.
Hope this helps !!
