Replacing oven gasket on oven
Need to replace gasket on oven at oven door.. not on the door, but oven itself. I cannot find model number. was purchased in 1976 and the model number that is on the stove is REG38 serial no. 52CL4186.Frigidaire doesn’t seem to recognize this model.
REG38 does come up at AppliancePartsPros but I cannot see the parts you need.
Perhaps you will be able to identify it.
[quote=denman;650471]REG38 does come up at AppliancePartsPros but I cannot see the parts you need.
Perhaps you will be able to identify it.[/quote]
I have the part. Not sure how to put in on the oven
Sorry but without actually being there I cannot say.
Some older type gaskets had wire clips as part of the gasket that held them on the oven.
