I shattered the outer glass on the door of my Maytag oven and am planning to replace it (I believe its part #74008683 and I’m also getting the double sided tape).
What is the best process for doing this? Do I need to take the door off the hinges to do this or can I just slide it in with the door in place? Is there anything else I need to do this?
This is very helpful information as I need to replace the outer glass in my oven also. I have the glass located and am also replacing both torsion springs while I’m at it. Question is about the 2-sided tape. Is that a special item to buy from Kitchenaid? I can’t find a part number.
[QUOTE=superbadoor;149888]This is very helpful information as I need to replace the outer glass in my oven also. I have the glass located and am also replacing both torsion springs while I’m at it. Question is about the 2-sided tape. Is that a special item to buy from Kitchenaid? I can’t find a part number.[/QUOTE]
The double side tape you are looking for is part number AP3122791
