[SIZE=2]Original shatterd and I ordered the replacement piece of glass. Instead of replacement double stick tape, there are three pieces of adhesive aluminum foil - two rectangles, approx. 4" x 5", and one strip, the length of the glass and about 1.5" wide. How do I attach (outer) glass to door frame? Looks like what I realy need is some type of heavy duty adhesive to use on the top corners of glass and door frame… [/SIZE]
