I have a KitchenAid double oven with the 3 & 7 buttons not working. I probably need to replace the control panel or possibly clean contacts…
Can someone help me with how it comes apart to service…
Most likely the problem is a bad control panel which has to be replaced.
In order to provide the correct part number I need the color of the control panel.
Hi Gene,
The oven is white.
I called RepaiClinic and she said that I needed part # 4448871.
I didn’t order anything just yet…I need to know how to get it apart first.
The part number you got from Repair Clinic is for the control board. I do not think this is a failure suspect in your case. Most likely the problem is a bad membrane switch which is coming as the control panel assembly.
In order to replace it:
Open the lower oven door and remove the screw holding the trim on each side of the oven. Grab the trim from the bottom, pull it toward yourself and slide it down to release the trim from the control panel tab.
Remove the screw on each side of the bottom of the control panel.
Pull the bottom of the control panel toward yourself and push it up to release from the tabs.
Unplug the ribbon from the control board. Remove all screws holding the control board and reinstall the control board on the new control panel.
Assemble it in the reverse order.
- The part number for the white control panel is [COLOR=#0066cc]AP2929485[/COLOR]
Here are the break down diagrams for the Kitchen Aid oven Model KEBS207DWH1
Thanks Gene, that was too easy!
I agree with your assessment of the problem.
In your experience do you think that a bad contact or cleaning something would solve the problem of the 3 & 7 buttons not working or is it pretty much cut & dry case of just replacing the membrane.
It’s a pretty expensive part ($350.00 )
Thanks again.
Of course you can try to clean the ribbon (using an eraser), but the rate of success in my experience is less than 15%.
The part is very expensive but still much less than a new oven.
Just a follow up…
I followed Gene’s disassembly instructions - which were simple - but stopped short of actually removing the control panel as I didn’t have a replacement yet.
I put everything back together and all my buttons are now working!
I probably moved something but I didn’t actually clean the ribbon contacts.
…Anyway it’s working now so I’ll keep all this information handy for when the control panel finally gives up for good…![]()
KitchenAid KEBS208DBS6 part #4448871
Found a company that repairs the control board which fries after completion of self clean (really bad design!). Thermal fuse tested ok, but I can’t seem to remove the ribbon to get to the control board out.
Please HELP!!
The slot has a small locks on both ends.
First let me say thank you for reponding to my email!
I was able to remove the ribbon harness and all the plastic wire tabs.
However, the ribbon separated from the plastic tab, which I hope I’ll be able to fix/reset once I replace the control panel. After reading the thread on this issue, I’m tempted to re-assemble everything, as the board looks clean to me–no apparent damage or broken filament fuse, etc. Perhaps the cut off/dead panel occured for some other reason? Someone suggested perhaps a fuse or cut off between the power source and conversion from the 220 to the 5 or whatever amp to the control board because of the heat/temp after the self clean process? Apparently there is a company that fixes/tests these boards, but I have to mail it to them for their assessment. Again, much appreciation for your reply.
Hi, I have the f2e0 message showing on my kitchenaid gas stove. I’m having trouble removing the front panel so that I can try trouble shooting the control panel. I’ve removed the screws and the front panel is loose when I pull from the bottom but once I pull it up over the 4 exposed metal pieces it seems to still be stuck on the sides. Any help would be greatly appreciated. Cory
Hi Cory,
What is the complete model number of the stove?
Hi Gene,
The model number is KGSA906. I also see the numbers 9762266 on the user guide…not sure if that means anything. Cory
Cory,
The model number you posted is incomplete. You can find it on the oven door frame or on the frame behind the bottom drawer. Verify and repost it please.
Hi Gene,
I was able to find the model number KGRA806PSS01. Thanks, Cory
Hi Cory,
Sorry for the delay.
The instructions are attached.
- The control board AP6014137
If you need the correct part number for the membrane switch, post the color of it.
Here are the breakdown diagrams and Replacement parts for Whirlpool KGRA806PSS01 30" Freestanding GAS OVEN CONVECTION | AppliancePartsPros.com
Removing the EOC and the user interface.pdf (553.0 KB)
Gene,
Thanks so much for the info! Cory
You are welcome Cory. Keep us posted.
I a searching for a part for my double wall oven, model KEBS247DWH8, the part I need is 8300386, the control panel with membrane. I am having the problem of the error that says that the connection between the membrane and the control board has gone bad. I have not been able to find anyone who carries the replacement part. Is there anything I can try?
Unfortunately this part is no longer available and no authorized substitutions have been identified.
