Replacing Jenn Air Glass Cooktop
My Jenn Air glass cooktop cracked, and I have ordered a replacement for it. The existing cooktop fits into my granite countertop, and can be lifted right out. Will I need any additional parts other than the glass top itself (i.e. clips, foam tape, etc) to complete the project? Thank you.
Replacement parts for JENN-AIR CCE3401B SURFACE UNIT- ELE | AppliancePartsPros.com
It does show foam tape (Item 1 in Section 2) which you should replace. I doubt you will be able to reuse the old stuff.
Also here is the install sheet.
https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%20AAECTDIRAII.pdf
AP4090121
If you click on the above another page will open with questions/answers on it’s install.
[Thanks very much for the quick response.
quote=denman;535503]Here are your parts
AP4090121
If you click on the above another page will open with questions/answers on it’s install.[/quote]
Denman, any chance you still have the replacement instructions/manual saved because I need it but that link doesn’t work and I can’t find it anywhere else? Thanks!
Found it! Here’s the new link: https://access.whirlpool.com/wdl/ws/file/09001a50801fbb03/dl/pdf
