purchased new glass top due to broken top. But looks like there was a gasket on old top. do i need to get a gasket and are there instructions on installing gasket on/with top. haven’t removed complete top yet. does gasket fit around entire top inside of trim? ![]()
Most times a replacement glass will come with its gasket already installed on it but if your particular one doesn’t come that way, yes, you’ll likely need to order a new gasket as the old one likely won’t be able to be reused. :rolleyes:
LINK > Whirlpool GY396LXPB00 Gasket, Glass Top (no picture)
The gasket usually goes directly onto the glass all around its edges and then the trims just get pressed over it.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
