I tried to unfreeze my water dispenser line quickly by using a heat gun and I might have overdone it. Now the water comes out in trickles only. I’m thinking of replacing the water line. I’ve been trying to find a guide on how to do this for this model but I was unsuccessful. Joined this forum to see if anyone can help. Thank you in advance!
Are you talking about the coil of tubing in the back of the refrig. side? You’ll need part 810
Parts for GE GSL25JFRFBS: Fresh Food Section Parts - AppliancePartsPros.com
Watch the video…
Refrigerator Cold Water Reservoir (part #WR17X11324) - How To Replace
Thank you for responding ThatGuy. No, it’s not the one at the back. It’s the one in front in the dispenser where the water comes out when you press your glass to get a drink.
That’s going to be a fun one. I’ve done that a couple of times.
Can you remove screws to remove the door seals and inner door liner?
Or is it glued together?
I’m not sure. I’m a little worried that I might not be able to put them back after.
