replacing frigidaire water filter housing
I have to replace the filter housing it is cracked. I removed the cover and screws. The water line is connected with a john guess push on elbow. How do I remove the filter housing from the elbow and also the elbow from the water line? I also believe I will have to replace the elbows. How do they install?
to remove the connections from the water line, you must press the collar towards the connector, while gently pulling the water line away from the connector.
