Replacing faceplate on GE wall oven
Brand: GE
Model Number: JTP55SM1SS
Main Symptom: Faceplate is peeling off
What happens & when: oven still works, just the faceplate is peeling off
I see that the exact replacement part is discontinued (WB49T10041), but I see on the site that WB27T11233 should fit per your appliance compatibility tool. I see there might be retrofitting required, can you let me know the exact part numbers I need to order to change the faceplate in addition to WB27T11233? The oven serial number is MR621307Q
If you measure the faceplate, does it measure 17.5" long or does it measure 15" long? Both were used on this model and the specific one is dependent on if a retrofit kit was installed or not. Measuring the length of the faceplate is the easiest way to identify which one is currently in place.
15" faceplate- WB27T11233 Oven Control Panel Faceplate | Genuine Ge OEM In Stock
