Replacing elements and terminal blocks
I have a cooker with the plastic terminal block i would rather if possible to change using the ceramic block and using the matching elements
can u please advise
thanks
replacing terminal blocks and elements
I can be reached at roslynjack@msn.com
You have to use original parts only.
