We need to replace the Electronic Push-Button Switch Membrane on our dishwasher.
Can we get instructions on how to do this? I am not exactly sure of the age of the dishwasher.
I did call and get the part number 9743241, to order this part on-line (which is cheaper) on the ********************.ca website the ******************** number is PS402286.
Replacement parts for Whirlpool KUDS24SEWH3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
I am a bit confused your post says the membrane has to be replaced but the numbers you give are for the switch assembly.
If you click on Item 2 in Section 1 a new page will open with a Q&A section which has some install help.
If your problem is that some of the keys do not work then it could be just dirty connectors.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
