Replacing drum slides/glides
what are the locations of the drum slides? do the red ones go on top as opposed to the white ones?
What is the complete model number of the dryer?
model# DHDSR46EE1WW thanx
There are no more red glides. You have to use green glides instead. You have to order two of each glides. They should be installed on the front drum bearing (#313 on the diagram). Two green glides (slides) go on top of the front drum bearing and two white - on the sides of it.
Here are the breakdown diagrams and Replacement parts for General Electric DHDSR46EE1WW Electric dryer | AppliancePartsPros.com
Thanx alot! Rec’d conflicting info from cust svc line, thanx for confirming for us!
