I have a Jenn-Air microwave (model jmv8000bdw) manufactured in 2000.
The outside handle and door are cracked. So I purchased a new door, but can’t for the life of me figure out how to get the old one off to get the new one on. I have found several threads with other brands of microwaves and this problem, but wondering if someone can help me with this specific model?
I took what looks like #6 off the old door and cracked it in two places. But I still can’t figure out what to do next… Any help?
I called a service person who will happily charge me $69 to come out and $72 hour. The door cost me $90 and I am quickly getting to the point that I should have probably just replaced the entire microwave…
I’m not exactly sure how your microwave is set up, but normally you would remove the inner door panel (#6), and then use a screwdriver to detach the door from the lower hinge. The door will then slide off the upper hinge.
just did this repair myself. if you simply remove the ventilation grill (#16), it provides the clearance to allow the door to be lifted - thus both mounting pins will slide up out of the hinges. no disassembly of the door is required. pop the old one off, drop the new one on, and replace the ventilation grill. 60 second job. Enjoy!
