Replacing Control Board and Glass cook top
[COLOR=#000000][FONT=Calibri]I have two issues with my KitchenAid electric range model kesc307hww8.[/FONT][/COLOR]
[COLOR=#000000][FONT=Calibri]1. I boiled over some water and now the display panel is blank. The touchpad still works, just no display. I believe that the control board needs to be replaced? - [FONT=Calibri]Part Number:[/FONT][FONT=Calibri] AP3176181[/FONT][/FONT][/COLOR]
[COLOR=#000000][FONT=Calibri]2. When cooking a heavy pot of potatoes, the glass cook top cracked and needs to be replaced. -[FONT=Calibri]Part Number: AP3837477[/FONT][/FONT][/COLOR]
[COLOR=#000000][FONT=Calibri]The question is, can a homeowner do these repairs? and where can I find instructions to do this[/FONT][/COLOR]
The board may not need replacing.
Have you tried unplugging the unit for a couple minutes to see if it will reset?
If it still does not work, I would unplug the unit and open it up, then dry the board off with a hair dryer.
Could be that there is just some moisture between a couple tracks or part connections and that is dropping the voltage to the display.
Here is a manual which should help with the repair.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=160
KESC307.pdf (184.8 KB)
[quote=denman;690143]The board may not need replacing.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=160[/quote]
I reset it, it didn’t work :mad: still no display - I’m going to have to replace it
