Replacing clock module-Jennair
This is a free standing gas stove. The control panel is in the front. Although the timer is no longer available I bought one ten years ago as I thought that the original was faulty but it wasn’t. Now it is. On inspection it looks as though the top has to lift off to access the controls but I can’t find the magic button. Any help and direction would be appreciated. Thanks Peter
Perseverance furthers!!! You undo enough screws and the top lifts off. The screws are underneath the burners. Ok for those who are looking for this part ( I guess if fits quite a few models ) you can email me. The problem with it was the clock didn’t show sometimes. If you touched the screen it showed the correct time. Did not affect the oven temperature etc . I appreciate this forum, thanks for being here. [email removed]
