Replacing Broiler Element On Ge Oven
I’m Trying To Replace The Broil Element On A Older Ge Built-in Oven Model J Kpo7g006bg. The Circuit Breaker Is Off. I Then Took The 2 Screws Out That Attach The Element To The Rear Of The Oven And Then Tried To Remove The Old Element. Element Came Out About 1/2 An Inch And Now It Seems It’s Blocked From Coming Any Further And I’m Affraid To Jerk On It.
Do I Need To Remove The Oven From The Cabinett As It Is A Built-in? Do I Wiggle It More And Harder So The Last Part Of The Element Will Come Out Of The Back Of The Oven? Just How Do I Get The Old Element Out? Jay
You may have to giggle it back and forth a bit to pull the wires out a little to reach them.
Nat
