Replacing Bosch Dishwasher Door Spring Pulleys
The nylon door spring pulleys/cords on both sides of my dishwasher need to be replaced as the nylon hook that connects to the door hinges snapped on both sides. I got the dishwasher out and the side panels off and I can see the pulleys wedged between the molded plastic bottom frame of the dishwasher and the door hinge plate/lever hinges but I can’t figure how the pulleys come out short of removing the door. Does the door hinge plate/lever hinges/door have to be removed to get the spring pulley cord assemblies out? They sure didn’t make it easy to replace a part that seems to fail quite often. Help! What has to come out to change this part?
[LEFT][FONT=AkzidenzGroteskBE-Regular]Lay the dishwasher on its back, [/FONT][FONT=AkzidenzGroteskBE-Regular]being careful not to damage the d[/FONT][FONT=AkzidenzGroteskBE-Regular]rain hose. Then using a small [/FONT][FONT=AkzidenzGroteskBE-Regular]screwdriver, remove the door s[/FONT][FONT=AkzidenzGroteskBE-Regular]prings by prying the spring plate [/FONT][FONT=AkzidenzGroteskBE-Regular]out from the base. [FONT=AkzidenzGroteskBE-Regular]Then remove the spring cable by unhooking it from the spring (look at the attached file).[/FONT][/FONT][/LEFT]
[LEFT][FONT=AkzidenzGroteskBE-Regular][FONT=AkzidenzGroteskBE-Regular]Here are the break down diagrams for the Bosch dishwasher Model SHV6803 UC/12 (FD 8105 -)[/FONT][/FONT][/LEFT]
[LEFT][FONT=AkzidenzGroteskBE-Regular][FONT=AkzidenzGroteskBE-Regular]Gene.[/FONT][/FONT][FONT=AkzidenzGroteskBE-Regular][/LEFT]
[/FONT]
Door spring.pdf (45.4 KB)
