Replacing Blower Wheel
My admiral dryer is 14 yrs old. I found out I need to replace the blower wheel and want to know if this is something I can replace or is it worth replacing since the dryer is so old. This is the first time I’ve had any problems out of it. Thank you for your help.
Could not find info on a LNC7744A71 but here are the parts for a LNC7766A71.
May be the same.
Model LNC7766A71
Not a huge job.
Is easier if you have a set of sir clip pliers to remove and install the clip (Item 12 in the “Motor and Drive” section.
Where do I look for Item 12 in the “Motor and Drive” section. I’m new at this. Thank you
Just click or double click on this link
Model LNC7766A71
